I'm looking for some advice about a case for a new system I am about to try and put together (my first
I'm planning to use a Asus P6T motherboard, and GTX 260 video card (probably an MSI one) in it. Also, I don't want to spend too much on a case if I can avoid it (preferably less than $100US).
I am considering the Antec Three Hundred case, but I am a bit concerned about whether the MB and Video card will fit ok in that case. Some reviews on newegg seem to indicate that with the larger cards, even if you can fit it in, it overlaps into the HD bay area effectively rendering two slots useless. Can anyone confirm this?
Some other cases I am considering:
- Antec Nine hundred (its a bit of a beast though)
- Noble NOB28A http://www.scythe.co.jp/case/noble.html
- Valuewave Kuroko http://www.valuewave.co.jp/item/kuroko.htm
I really like the Lian-Li cases, especially the P50R, but they are a bit out of my budget
Any suggestions/ideas/advice?
Thanks
Thanks
