DaConfusion
- Dec 14, 2005
I will restart my computer and use my laptop to post the bios settings I have enabled.
CoreTemp will not run on my computer for some reason (assuming 64 bit?)
What heatsink are you using? When I used the stock heatsink and overclocked to 3Ghz, i would see temps as high as 85C. I switched to using a Thermaltake mini-typhoon and I was able to bump the OC to 3.3 but the temps would still go up to ~77C during load. Now, using my Tuniq Tower 120 it rarely goes above 65C during load.
These are all core temperatures btw, which will be higher than what you might be used to on older chips or motherboards that had sensors on the socket or not otherwise directly on the core.
Under the Advanced Tab
Configure Advanced Cpu Settings
[Manual] CPU Ratio Control
[ 9] Ratio CMOS Setting
[DISABLED] C1E Support <----Ill turn it on once everything works
[Enabled] CPU TM Function
[Disabled] Vanderpool Technology <----Was enabled for some reason, off now
[Enabled] Execute Disable Bit
[Disabled] Max CPUID Value Limit
Thank you so much for any help.
The paste I am using is Artic Silver 5, and the application method was as on their site, one thin line, place heat sink on top, turn 1 degree left and right.
See now it has 16C (i know it says 15, buts averaging 16C)
I just dont think that program is showing me the right number since everyone here says its usually off by 15C
