I have this board with a q9650 8gb of ozc reaper. I have it stable at 3.65ghz and cant go further. I am pretty new at OC'ing so I dont know what other settings to change beside cpu voltage. I just want to see if I can hit 4.0ghz on air. Any help to try and get a little more out of this guy.
EDIT: I got the system to 3.7ghz by upping the mch to 1.3, but fails occt after 3 hours. I dont remember what my cpu voltage was and im currently at work
Code:
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio............................[ 0 ]
CPU Frequency 3.65GHz...........................[ 406 x 9 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 406]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 800mv ]
PCI Express Clock Drive.........................[ 900mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance [Standard]
Extreme Memory Profile (XMP)....................[ Disabled ]
(G) MCH Frequency Latch.........................[ Auto ]
System Memory Multipler.........................[ 2.66D ]
Memory Frequency 1066...........................[ 1083 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Motherboard Voltage Control******
Load-Line Calibration [Disabled]
CPU Vcore [ 1.2375 ].......................[ 1.25625 ]
CPU Termination [ 1.20 ]...................[ Normal ]
CPU PLL [ 1.50 ]...........................[ Normal ]
CPU Reference [ 0.760 ]....................[ Normal ]
MCH Core [1.100 ]............................[ Normal ]
MCH Reference [0.760 ].....................[ Normal ]
MCH/DRAM Refernce [0.900 ].................[ Normal ]
ICH I/O [1.500 ]...........................[ Normal ]
ICH Core [1.100 ]..........................[ Normal ]
DRAM Voltage [1.800 ]......................[ 2.200 ]
DRAM Termination [0.900 ]..................[ Normal ]
Channel A Ref [0.900 ].....................[ Normal ]
Channel B Ref [0.900 ].....................[ Normal ]
