gweminence
- Dec 22, 2006
Hello everyone.
Just built a new build with the q9550, and was wondering if my temps are normal-ish. I get low to mid 40's at idle, and mid 50's-ish under load my normal useage load, though it goes up to 60 with intelburn. Are those decent temps for 24/7?
I overclocked it to 3.6gHz easily, with no change to voltage, so I actually began lowering the voltage, I think I'm down to about 1.3v now. I had it lower, but it wouldn't boot. I have the xigmatec rifle cooler with a scythe fan.
Thanks in advance.
Thanks in advance.
