Q9450 Temps
wankelguy13b
Well I got Real Temp 2.41 and I think I got bad temp sensors. The first core idles at 32 C, but the others are stuck at 45, 43, and 42. What can I do about that? Can I RMA it or is it the program? This sucks. It's only a week old, maybe Microcenter will trade it.
Did you use the test sensors button?
The sensors could just be stuck at the lower temps, but once they reach a certain temp they will start to work again. Who knows what those temps are though. Might load them up with Orthos and see what happens.
I tested them with Real Temp and it gave me 4, 5, 5, 5 for the test. Then turned on orthos and the temps went from from 33, 46, 45, 44 to 43, 54, 55, 55
