thedocta45
- Oct 10, 2007
I recently placed a Q6600 into my Dell XPS 410. I used a credit card to lay AS5 on the Q6600. The coat looked even and I used the recomended amount on the AS website. However the CPU temps idel at 37 C on core 0 and 1 and 31-33 on core 2 and 3.
The cores get up to around 60 after Prime95 has been running for a while. They don't go over 65 C on any of the cores. The temps even out a bit more around 60 or so.
Im just trying to figgure out if i messed up the AS5 application.
I know for a fact that the CPU fan can run at a much higher speed, and I'm wondering if there is a way to bypass the mobo and make a fan controller for the two fans the system has.
