Well I pre-ordered my Q6600 G0 Stepping. My current PSU Doesnt have a 8 pin cpu connector, only 4 Pin. I dont really feel I need to get rid of my current powersupply because I do not game or use SLI. I really do not consume that much power.
After researching with a friend of mine, we determined it would not be safe to use a 4 pin to 8 pin adaptor. Instead we found something that would work much safer, Since its getting 2 12V sources from its own rails.
I need to know for sure if this will be safe to run until I can get a 8PIN PSU.
The way this connector works is that it uses 2 seperate 12V molex connectors, to power each 4pin. The 4 pin connector is just 2 ground and the other 2 pins are 12V source.
So using this adaptor here should work fine for right?
http://www.newegg.com/Product/Product.aspx?Item=N82E16812887002
At least better than using a adapter that converts P4 directly to P8, without using the 12v molexs? Like this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812201005
Also keep in mind the motherboard does not REQUIRE the 8pin, but the chip MIGHT, considering theres 2 more additional cores.
jtom/tscompusa
jtom/tscompusa
