- Jan 26, 2007
hey, guys
So. i got the apples to o/c and play with settings. If you could look and it and tell me how good i did i guess. This is my first real o/c on this computer like changeing the vcore ram and timings. so this is my first try. had some trail and error but i think i got it down. so let me know if i can do anything better on this o/c
here is my setup
Thermaltake Armor series 8000
Thermaltake Toughpower Cable Management 700W
Asus P5K-V
Intel Q6600 G0
Zalman 9500
Cosair XMS 2 DDR800 2x2GB
PowerColor 1950Pro X2 Cooler
I am using Pc Probe II/Pc Wizard 2008/AI Suite/SpeedFan
my temps are as followed.
Running Prime95
Underload 4 cores %100
Cpu temp 45-46-47c
Core 1 57c
Core 2 55c
Core 3 52c
Core 4 52c
Vcore is from 1.28 idea and 1.216. load
sytem 35c
so what else can i play with. that will make it run faster lol. and i am enjoying it until i burn something up. but i will not let that happend if i can.
my ram timings
Freq 400.7
FSB: Dram 5:6
Cas# 5.0
Ras# to Cas# 5
Ras#5
Cycle time 18
Command Rate 2T
Ok, so i played with my setting some more and here is what i got.
i changed Vcore from stock to 1.3250
now my Vcore at load is 1.184
now my Vcore at Ideal is v1.272
My temps now are
Cpu 45c Load 4 cores %100
Core 0 56c
Core 1 55c
Core 2 52c
Core 3 58c
Cpu 28c
Core 0 37c
Core 1 35c
Core 2 31c
Core 3 31c
Is there any way i can lower the Vcore a little more to make it a little cooler, or should i get a better cpu cooling setup for air? Will not use water setups yet.
My New Ram Timings
changed the speed from 800 to 667
Freq 334.0
FSB: Dram 1:1
Cas# 4
Ras# to Cas# 4
Ras# 4
Cycle time 13
Command Rate 2T
Thanks Everybody that will help me.
here is my setup
Asus P5K-V
Intel Q6600 G0
Zalman 9500
Running Prime95
Cpu temp 45-46-47c
Core 1 57c
Core 2 55c
Core 3 52c
Core 4 52c
sytem 35c
my ram timings
Freq 400.7
FSB: Dram 5:6
Cas# 5.0
Ras# to Cas# 5
Ras#5
Cycle time 18
Command Rate 2T
My temps now are
Core 0 56c
Core 1 55c
Core 2 52c
Core 3 58c
Cpu 28c
Core 0 37c
Core 1 35c
Core 2 31c
Core 3 31c
My New Ram Timings
Freq 334.0
FSB: Dram 1:1
Cas# 4
Ras# to Cas# 4
Ras# 4
Cycle time 13
Command Rate 2T
