Logical Disconnect
- Sep 7, 2006
So I've been looking to get a new monitor with component inputs (of which there seem to be very few!) and the Asus PW201 caught my eye. Problem is, I can barely find any info about it, anywhere. Looking at older threads, it seems like at least a couple of people have one, so I was hoping that they (or anyone else in the know) could answer a couple of quick questions - surprisingly enough, about the component inputs.
1. Is it possible to input 1080i (say, using an XBOX360) and have the monitor scale it down, as some other 20/21 inch monitors do?
2. If I'm inputting a signal into component at 16:9 (1080i, 720p etc.), will the monitor stretch it to 16:10 or will I get black bars at the top and bottom? I read in the manual that there are a few different 'aspect' options (normal, panoramic, full, zoom) but I'm not sure what exactly they do, and I can't find any shop that has the monitor on display to check it out.
3. I guess the main question should be, is the component quality any good? Hopefully someone can offer their impressions!
Last thing: I read somewhere that the PW201 isn't HDCP compliant - does anyone know if this is true (there seems to be no way of contacting Asus) and if so, is it really that big a deal?
It just seems like every monitor I look at between 20 and 24 inches that has component inputs has some major issues, either with them or with something else. I heard the NEC 20-inch is pretty good overall, but the problem is that in Australia we only get DVI and VGA
Thanks!
Thanks!
