push or pull on hyper 212 plus
bastage
Pics of your wife?
Title says it all. Reason I ask is I just received the cooler from a forum member and its set to pull with a gentle typhoon, where as I have always ran single fans as push. Help appreciated as I am assembleing the system its going in now.
Posted via Mobile Device
Slap another one on and do push/pull.
If only one, push is the way to go to bring the cool air from the front of the case over the heatsink.
John
Can't go wrong with a push/pull if you have the clearance. As John said though, push would be more optimal if you had to choose.
I have the clearance, but only one of those particular fans. So it would be Mitch matched with anything I have unless I used the 2 stock 120's from my had 912.
