Pump Relay Switch Kit Wiring?
Brian@3DGPU
Guys, Just got a Hydor L30 and one of these pump relay switches (at the bottom).
The wiring diagram shows three wires coming out of a pump cord (I think they are talking about the Eheim) The Hydor only has two and they are not marked or colored.
Any help?
I found that one...my Hydor has a standard two wire power cable...not like that one
Couldn't you just stick a lead into each but the ground spot?
If the pump flow is backwards or isn't working right, reverse the leads between hot an neutral.
I hooked up a Via Aqua 1300 [also 2 wire] to that relay & it works fine.....the wires were blk/white though which does make it easier;)
