Ok, this was the setup I planned on running, http://www21.brinkster.com/tdginc/watercoolinglayout.JPG
But, I just relised, I am not going to be able to put two L30s in my case and have it look cool :-P
Any whoo, I was thinking about the CSP X2. It is a cool little pump that can be combined into to, like what I was origanally planning on doing. I would do everything the same as my current layout, but the pumps are smaller in size. Basicly have one pump, pump water to the CPU, and have the other, pump to the GPU, and have them meet togther before they hit the radiator.
How do you guys think it would work out? Or do you just think I should use the two L30s?
Thanks
Thanks
