sonnybobiche
- Jan 1, 2006
I had replaced my stock cooling with the very shitty thermaltake bigwater SE kit. The pump failed two days ago (after about a month of use) but I didn't realize it. I used the computer for a day until I noticed artifacting (6600GT is in the loop as well.) I pop open the machine and see that the pump has clearly failed and the water has receded back into the reservoir. Both the waterblocks were running bone dry. I immediately shut down the system and ordered a DD Mag pump + 1/2" clearflex hose. Also ordered 1/2"-1/4" barbs, because the flippin' system is all 1/4". Hopefully I'll be able to phase out the components slowly to 1/2". (Or quickly if they fail, as I expect they will.) The moral of the story is don't buy cheap watercooling components. BTW this miracle occurred on an amd 64 3200 and an msi 6600GT. I think the only reason the system continued to function was the huge TT armor case with the large top opening and the rad fan producing airflow through the case. Thoughts?
