ComputerGeek
- Dec 27, 2010
Hello Guys, Happy Thanksgiving! Anyway I was wondering I thinking about buying some new power supply's and then Sleeving them. I was wondering what wattage is the most Common that people use? What brand should I go with? Only Corsair ? Or others? Do you know if any manufacturer allows you to sleeve the PSU without voiding Warranty? Also what colors would you Suggest? THanks!
