I have never sleeved a PSU before and decided to start with the 8 pin + 4 extension cable that came with my Obsidian 800D. I popped a few out with a staple but i managed to yank a few out that were not ready to be removed leaving the pin inside and the wire in my hand.
This meant that i now could not possibly fit those two cables in the tiny pin, so i am sticking with only the 8pin.
I used needle nose pliers to put the single cables back in the pin, but i have a problem on the few pins that used to have 2 cables going in.
Even though i clamp the pin down tight around the now single cable, the wires pop out of the connector when it is attached to the motherboard. I am thinking of putting the wire back in the pin and using some kind of adhesive to stay put.
Do i continue to try and get those damn wires to stay in the pin? try and get another cable from corsair? or cry and do nothing
