PauliePaul
- Apr 25, 2008
Hello,
Just completed a build for a family member using a Raidmax case, 5 80 mm fans, 1 dvd rom, 1 dvd burner, an AMD Duel-Core 4200, evga 7800 gtx 512, an ASUS A8N32-SLI Deluxe mobo (ebay purchase, used), 2 gigs of ddr, and a 150 gig sata raptor. I used a Topower 500w psu: http://www.newegg.com/Product/Product.aspx?Item=N82E16817342010
Everything worked fine at first, but after moving the system to a permanent location it started having a problem; it keeps restarting during bios/posting. After disconnecting all usb ports except the keyboard, it began running normally. Is this likely caused by the psu or could it be the mobo?
As I no longer have the system I've yet to disconnect the dvd players, fans, 1 of the gigs of ram and reconnect the other usb ports and start it in that config.
Thank you.
Thank you.
