so i just rebuilt my system with the following new parts...
q6600
p5k-e wifi/ap
8gb ddr2-800
in addition to:
5 hd's (1 ide 4sata), and a nec burner
6800gt
fan controller w/ 4x fans and 4x ccfls
1 leadtek tvxp2000
1 ati hdtv wonder
and a floppy drive
I was powering it on an OCZ-520 12U 520 watt psu, and it runs ok on the default settings, but when i started to oc and prime each of the cores i watched as the 12v dropped from 11.8 to 11.6 to eventually 11.2... i stopped it right away and decided that i need a new psu.
What would you recommend if i plan on adding an 8800gtx or whatever the next big nvidia card is around next christmas? also plan on adding 1 or 2 more hds at some point... want to run the q6600 g0 at 3.8 (and with the current temps and my huge ass heatsink i think it should be able to handle it)...
thanks,
mike
would this psu handle it?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153038
and do rosewill psu's still suck? (specifically this one)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182072
my current voltages for the default q6600 settings are
1.23 vcore (was set to auto in bios but seems to drop to 1.23 when i prime all 4 cores at once) its at 1.25 if i only prime 1 core.
3,28v 3.3+
5.09v +5
11.65v +12 (jumps up to 11.82 if idle)
q6600
p5k-e wifi/ap
8gb ddr2-800
in addition to:
6800gt
1 leadtek tvxp2000
1 ati hdtv wonder
and a floppy drive
thanks,
mike
3,28v 3.3+
5.09v +5
