PS3 USB problem
Streber
Alright. So as of yesterday my USB ports stopped working on my PS3 Slim 250 GB HDD.
I have been trying to figure out what has been causing the .problem and I think I have it down to only one possibility. The south bridge *Cries*
I have hard booted the PS3,
Checked USB voltage (No Load) = 5V
Checked USB voltage (Load) (I used an external hard drive the drive boots up and spins) = 5V
I connected one of my controllers to another PS3 Via the same USB cable and it worked fine, now the controller won't connect to my PS3 (whooops) however I have one controller left and a friend of mine lent me a controller charging dock so I am okay in the intern.
I will be getting some precision screw drivers to check connections and cables however they seems to be getting power fine so I am assuming it's the south bridge.
My questions are as follows, one if it is the south bridge what do you recommend? Second do you have any additional troubleshooting steps you can suggest that might help I am all ears.
I appreciate your guys's time and help :D
So I have rebuilt the PS3 and its the bored, No connections or anything I can do.
