Well here is my work log..
This work log is for The modding of my J-Pac Black Voodoo Case, Basically Modding it into a J-Pac Blue Voodoo but cooler..
Also, i cut out the design covering the window
Case at the Beginning,
The Tools I Will Be Using
Panels Removed Except For The Top
Window Panel And Faceplate
With The Faceplate, and all plastic parts, i first layed down a blue base coat and then let that dry and add the metallic flake
Front Grills
Window panel after first coat, can see all little spots. =\
Front Panel upclose and personal
side panel and drive bay covers
Facepaint after 3 coats, 2 Blue Coats, 1 Flake Coat
Shot With Flash, can see where the paint ran.
Shot without Flash, Can't see anything bad
FAn grills cut out with flash on,
Fan grills cut out with flash off
Thats all for now, Stay Tuned
Front Grills
