Project: V2000
Impact9
I have no ideal really what I plan to call this or my direction. First off $ is a bit tight after buying this case and new drives. I'm waiting on a new motherboard, CPU, and Video Card. Water cooling is still up in the air so I may wait till I return to the US before doing that.
Specs to date:
DFI Lanparty NFII Ultra
AMD XP3000+
2x512 Corsair XMS3200LL
3x160G Seagate NCQ SATA II
GeForce FX5200 (temporary)
NEC 8x DL DVDRW
Yamaha CRW-F1 CDRW
Antec 480w NeoPower
The normal stuff is being worked on right now. Being a V2000 wiring is a big challenge so I hope this can help other Lian Li V-Series owners. On to the pics!
The FX5200 is going first to be replaced by a 800XT VIVO or AIW so I already have a power run direct to the card on its on power line. Depending on the video card temps I may remove the 3d card cooler. I am going to order a massive 300G+ SATA drive to act as long term storage that's the reason for the loose SATA cable. The power to the SATA is temp and will be sleeved once my last HD arrives. The blacklight and inverter is temp installed until my heat shrink arrives.
The biggest key to this case is taking advantage of the space between the hard drive racks and along the panel recesses. There is some room between the side of the case and the interior dividers to route wires between. I did have to extend the power leads to the CD/DVD and hardcano 12.
Stay tuned there's more to come! ;)
I'll have to take it outside today when the sun comes up and try again. Lighting in my room is indirect so i had to use a flash.
I like your crazy colored PSU sleeving :D I also like the way the V2000 is set up. It's much better than the V1000 because there is more space for the PSU wiring in the lower compartment. Hopefully you decide to do WC, you should definitely be able to have a nice set up with that case.
Nice :)
I need more money to be able to do stuff like this. I am a student without a job :(
What PSU is that btw?
Antec NeoPower 480. I'm going to change the IDE cables to blue. So all my data cables will be blue and power cables yellow. Crazy combo but eye catching. :) Been raining all day so I can't get any better pics just yet.
Thanks. Yeah, I'm need to buy some new ones. I have several different colours. I bought a round cable and it turned out to be the wrong one, but it is the same colour and texture as my PSU cables :)
