Project: Silent AC Rocketfish
jester55
Like many here I have acquired the Rocketfish/Lian-Li for my new build. I have seen some extraordinary rigs based upon the RF and I thought I would give it a go. I have built computers for years, but never have I done any modding!:eek:
So technically, this is my first project! With that in mind, any helpful criticism/feedback is wanted and needed. I need all the help I can get!:D
theplaidfad over at Anandtech inspired me with his Silent WC Rocketfish project. I thought I would use some of his ideas but with an air-cooled system instead. I'm not interested in WC yet, but I may go that way in the future.
I only have a few main goals in this project:
1. Silent/Very Quiet System
2. OCing my Q6600 to around 3.3-3.6GHz on air
3. Making the inside aesthetically appealing
4. Channeling the air in a way to increase air-flow with low rpms
5. And any other suggestion you good people might have!
I am coming from the following very noisy rig:
-DFI LanParty Ultra-D MOBO
-AMD Opteron 170 CPU w/Thermalright XP-90 HS and Panflo Fan @ 2.5 GHz
-G.SKILL 2GB (2x1GB) 184-Pin DDR SDRAM DDR 500 PC 4000
-EVGA 7800GT 256MB GPU
-(2) Seagate Barracuda 7200.10 ST3500630AS 500GB
-(1) Western Digital 74gb Raptor
-OCZ PowerStream 520W Adjustable SLI PSU
-Antec SLK3000B ATX Super Mid-Tower w/(2) Antec 120MM Tri-Cools
Here is my new rig parts:
-Abit IP35-Pro MOBO
-Intel Q6600 G0 SLACR w/Thermalright Ultra-120 eXtreme and Scythe S-Flex 1600RPM Fan
-G.SKILL 8GB (4 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000)
-EVGA 9800GTX GPU
-(3) Western Digital Caviar SE16 WD6400AAKS 640GB
-Corsair TX750w PSU
-Rocketfish/Lian-Li Case w/Enermax Multifunction-Fan Controller Panel
-Material for noise dampening and air channeling (Peel&Seal Roofers Tape, foam floor-mats, and velcro)
I am going to use roofer's tape to line the inside of the case decrease to vibration and noise. The floor-mats will be cut and mounted via velcro in order to direct airflow and dampen noise. I am also going to create an air-tunnel with the floor mats for my hard drives. Here is a diagram of how I intend to direct air-flow.
Click Here to View All Pics!
Thanks for looking and please don't hesitate to give feedback as I update the post and pics!
-Jester
I think the case will be hot and smell like rubber.......good luck.:eek:
Time to update what I got done last night. Seemed like a lot of cutting because it took me so long. If you would like to look at pics as I explain my progress feel free to view my album. My pics kind of jump around because I was kind of bouncing around a lot on what I was doing. My main objective last night was to get all my aluminum cutting finished. Everything I cut was to increase air-flow and hopefully reduce turbulence thereby reducing noise too.
I reversed the GPU/PCI fan to make it an intake and mounted on the outside of the air-duct to reduce drag from being so close to the wall of the air-duct. My 9800GTX should still fit nicely assuming my measurements are correct. If not, I will probably then use the dremel on the fan, or re-drill the mounting holes a bit. I also cut out the rear grill covering the GPU/PCI fan air-duct. This should increase air-flow as well. I plan to put trim around the edges to hide my dremel job.
On the front I cut the "H" bracket out after taking the fan and filter out. The edges came out pretty smooth. I don't plan on using the filter due to noise and air-flow restriction. With the door closed there seems to be inadequate air-flow due to the restrictive holes on the sides of the front door. If I take the door off I start to work against a silent machine. In order to increase air-flow through the front fan, I drilled ten 1/2" holes in the front lip that support the front face. The holes shouldn't be seen at all, once everything is together.
Next, I cut out the two bottom grills for the PSU. I plan to close off the PSU in the case to prevent the PSU from working against the direction of air-flow. By cutting the bottom grills out, I should have adequate cooling for the PSU, once it is closed off from air in others of the case. The feet on the case should still be adequate for air-flow since I keep my computer on my desk. I plan to put trim around the edges to hide my dremel job.
So, this is where I am at so far. I do have a few concerns as I mull over what I accomplished last night. I have read several times that impeded air-flow results in turbulence and noise. Hence why I have gone to such extremes so far to make the air as free to flow as possible. My concern is that I am also creating a dust magnet that I can not control. I do blow-out my cases every month or so.
Another concern I have is whether the front intake fan will produce enough air-flow at a low rpm. I am tempted to re-work my air flow by creating a shelf similiar to the P182/180's that closes off the bottom the case from the top. For that to work, I would need to install a drive-bay fan. My fear in this is more noise with the added front intake.
Thanks for looking and thanks for the feedback!
-Jester
Subscribed. I'll be doing somewhat similar things with custom ducting, so I'll be watching.
Thanks, I appreciate that. I got the ideas of custom ducting from BlueFront over @ SilentPCreview and theplaidfad @ anandtech. We'll see how it all works out!
-Jester
Quick update on what I finished last night. I had a pretty long day at work yesterday, so I didn't get much done at all. Basically, as you can see in the pics, I have started applying the Peel & Seal roofer's tape to the front of the case. The Peel & Seal is going on nicely. It does smell a little if I get my nose within an inch of it. Overall, so far, there's no smell at all within my room. And, that is with the complete roll of Peel & Seal opened and sitting in my room! I am happy so far because the possibility of smelling like a roof was a concern. From what I have read at silentpcreview.com forum, any smell I might have will dissipate/dissolve if I set the case outside for a couple hours on a hot dry day. I am really impressed how well this stuff deadens vibration in the case. When I thump the sided with my finger, you can definitely hear a difference! I hope to get a lot more done tonight - possible finish apply the Peal & Seal! I did purchase some rubber window trim for the aluminum edges and double-stick tape to apply the floor tiles when I get to that. Until next update....
-Jester
