Project Sapphire Ice
jjsky5000
I got my overall design for this mod when i was designing the lenovo ice build, A smaller compact ice cube made for Gaming !!! but i also really wanted showcase the components. After a few drawings and ordering the materials i was ready to begin.
A Big Thank to Sapphire Tech, & Kingston for letting me build a unique case
Components:
Danger Den 7 Slot I/O Shield for Custom Cases
Danger DenMC-TDX Block for LGA 1155, 1156 i3, i5, i7
Danger Den-RAD-Reservoir
Danger Den-CPX-Pro 12V Pump
3/8" Blue UV Danger Den Tubing
Stealth GTS 240 Black Ice Rad
Feser One - UV CLEAR Illusion - F1 - Coolant
Enermax Apollish Vegas 120mm x 25mm
Mod/Smart Supreme System Sleeving
Mod/Smart 20 Station LED Board - Base w/ 10x LEDs
Tailed Red 5mm LED w/ 2 Pin Mobo Header Connector
Bulgin Switch Black Switch - white LED
Silmar 41 casting resin
Fluorescent Acrylic Plexiglass - Blue
Clear Acrylic Plexiglass Sheet - 1/4'' Thick Cast
Sapphire Pure Black P67 Hydra-LGA1155
Sapphire HD6950 Flex
Intel Core i5-2500K Sandy Bridge
Blue Ray Burner
Antec 1200
Kingston 96GB ssd
Kingston hyper 8GB mem
I started by drawing on a wooden sheet for the mold where i want the components to fit.
then i started creating the molds for the base
Poured the resin
after a day of curing in the sun
A rough shell base has begun.
Framing the base !!!
measured up the aluminum fram around the plexi bottom
PS fan cutout
MB board tray cut out
resizing the ice base
fan & rom bay cut outs I used a router for fan cut out and upper plexglass
test fit
:DI think I would reconsider the aluminum and go for a acrylic support system. I wouldn't want to see the metal through the case. My 2 cents said I'll be watching.
My favorite part of the build ecting and illuminating The Sapphire Logo.
laying everything out for full assembly
the first side panel
added the sdd and the front logo
Rad & fans
added the Blue ray & PS + side panels
Cutout for the upper case fan to blow on the GPU
Super tight fit for water cooling and wires
cleaned up the wiring
Dropping the MB onto the base.
Some final pictures, sorry i didnt have too many pics, 30 day time from to get this to Sapphire before being shipped E3 in LA.
That looks very nice, especially the dark shots with the case illuminated. Kudos to you!
now jj, i want to see this acylic work used in a different way. May have some ideas :D
