Hi everyone,
First of all I'm 16 years old boy in estonia and I work in a company(only at summers) that makes stuff with aluminium so I can get everything I need to make a computer case from there
I have allready started this project couple of days ago, Project name is RKO.
Its going to be a alu case using 2mm alu and for the frame I will use some old computer case,I'm going to make it look like a lian-li v1000 case...
Well here are pictures for you
This is what the alu looks like
Its covered with some protective plastic...
This is how far the case has gone...
the Inside will be cut away soon(the frame part)
A front view
These I made today at work, they will be frame parts where I will fasten the right side...
This mesh I also got from work and I will use it in a window some were...
And this is the window glass..its not plexi its somekind of plastic 1,5mm but I got that for free and if I bolt it in then its strong as plexi ( I hope )
These I will use to put everything together, they are m4 bolts 10 mm long...
A front view
