Project: Reptile
aranlong
I had an idea to build a wide full tower case with this reptile cage as a base
http://www.ebay.co.uk/itm/MESH-REPT...rs_Insects&hash=item2567ce2b02#ht_1964wt_1037
Before i start the build i have done some initial designs i will use black 5mm acrylic for all the external surface and it will have a clear window on the left section with the three doors and then i will be able to hide the psu and any water cooling in the bottom.
This is only an idea at the moment but i hope to start building by december.
Thanks for reading.;)
Sorry forgot to mention that i could use the large door with higes as a rotatable motherboard tray.
Thanks again.
FYI: Per the forum rules, your first post must contain pictures. Threads must show work in progress.
