It’s time again to build a new system. I am quite poor, so the idea is to save as much money as possible on the build. I don’t plan on skimping out on essential components, but certain things, such as the case and certain modding supplies, I’m not spending a dime on. I have a ton of random scrap around...speaker grills, plexiglass, copper sheets and copper tubing, vinyl hose, etc...that I plan on using in the build.
I acquired an old p3 tower that I plan to use for this build. It comes with a removable ATX motherboard tray, two 5.75” drive bays, and six 3.5” drive bays (three of which are housed in a removable tray). The spot for the power supply is at the top back.
The construction of the case is very solid – it is 1mm thick steel and weighs 8 kg (17lbs) empty. Both sides of the case as well as the top are removable.
I don't want to give too much away on what my build plan is, but my timeline for completion is a few months. In that time, I plan to transform this very generic looking case into something truly unique and spectacular.
