Project Necromonger
Yaik
Project Necromonger
Specs:
AMS Genesis Beige ATX Full-Tower Case, Model "CF-Q45-1" -RETAIL
Specifications:
Case Type: Full-Tower Case
Color: Beige
Material: 1.0mm Nippon Metal
Drive Bays: 5.25" x 5/0, 3.5" x 1/3 (external/internal)
Expansion Slots: 7
Front Ports: N/A
Power Supply: N/A
Cooling System: N/A
Motherboard Compatibility: Full ATX
ASUS "A8V Deluxe" VIA K8T800 Pro Chipset Motherboard For AMD Socket 939 CPU -RETAIL
Specifications:
Supported CPU: AMD Athlon 64/Athlon 64 FX
Chipset: K8T800Pro + VT8237
RAM: 4x DIMM Dual Channel DDR400/333/266 Max 4GB
Slots: 1x AGP 8X, 5x PCI
Ports: 2x PS/2,1x COM,1x LPT,8x USB2.0(Rear 4),1x IEEE1394,1x RJ45,2x S/PDIF out,Audio Ports
IDE: 2x ATA 133 up to 4 Devices, 1x ATA 133 up to 2 Devices by Promise 20378 with RAID 0/1/0+1
SATA: 2x Serial ATA with RAID 0/1, 2x Serial ATA by Promise 20378 with RAID 0/1/0+1
Onboard Audio: Realtek ALC850 8-CH
Onboard LAN: Marvell 88E8001 GbE
Onboard IEEE1394: 2x 1394 ports
Form Factor: ATX
AMD Athlon 64 FX-55, 1MB L2 Cache, 64-bit Socket 939 Processor - Retail
Specifications:
Model: Athlon 64 FX-55
Core: SledgeHammer
Operating Frequency: 2.6GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/1MB
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 939
Multimedia Instruction: MMX, SSE, SSE2, 3DNow!, 3DNow!+
Warranty: 3-Year Warranty
Packaging: Retail box(with Heatsink and Fan)
Mushkin Hi Perf LII V2 Dual Pack 184-Pin 1GB(512MB x 2) DDR PC-3200 w/ Heatspreader, Model 991357 - Retail
Specifications:
Manufacturer: mushkin
Speed: DDR400(PC3200)
Type: 184-Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2-2-2
Support Voltage: 2.5V - 2.8V
Bandwidth: 3.2GB/s
Organization: two 64M x 64 -Bit
Warranty: Lifetime
Western Digital Raptor 74GB 10,000RPM SATA Hard Drive, Model WD740GD, OEM Drive Only
Specifications:
Capacity: 74GB
Average Seek Time: 4.5 ms
Buffer: 8MB
Rotational Speed: 10000 RPM
Interface: Serial ATA
Features: High Performance SATA Interface
Packaging: OEM Drive Only
Plextor 12X DVD+/-RW Drive, Black, Model PX-712SA/SW-BL, Retail
Specifications:
Write Speed: 12X DVD+R, 4X DVD+RW, 8X DVD-R, 8X DVD-RW, 48X CD-R, 24X CD-RW
Read Speed: 48X CD-ROM, 16X DVD-ROM
Interface: SATA
Buffer: 8MB
OS Support: Windows XP/ 2000
Features: Lossless linking technology, Buffer UnderRun Proof technology, POWEREC, GIGAREC, Q-CHECK, SECUREC, SILENT MODE
Sooooooooooo....what ya' think???? :D
this oughta be sweet :D
i would love to see a spoiler preview piccie...
and if you can't draw all that well, do the best you can and pm me the image. i'll take it from there and make it goooooooooood :D
XeRo_Dark said:
chronicals of riddic was a godly movie, i cant wait to see how this mod turns out :D
Got that right!
I'm looking forward to seeing how you do this!
sorry, i thought the movie was lame and predictable....but really, with those specs ANYTHING will be awesome.
except beige. lol
I'm trying to make the 3D model in Pro/E software then I'll have a picture to show, and NO is NOT going to be beige!!!! :D
necromonger Eh... I have a case based on it in design haven't started yet. can't wait to see it.
Sorry for the delay but here is an update..... couldn't follow the first idea but I wanted to stick with the same theme.
Here you'll see my progress.
Yea I was going to do my V2000 with this same theme a while back but changed my mind since there wasn't anything released like reproduction helmets and props. Yours seems to be coming along nicely! Wish I had the time and patience to do this level of detail. Keep the updates coming
Troney1169 said:
Looks good thus far but i think i would've started with this case.
yes this one
kinda goes with the vertical lines of the necromonger's ships
I agree, but my idea was not to make it flat on the sides, but round shape it all around, so I needed a really cheap case, just for the frame, this one cost me $15 USD. :D
Mysticcal said:
I'll buy that DVD burner from you and run a raid 0 with mine! :)
DVD and RAID is like apples and oranges they both grow on the tree but have nothing to do with each other :confused:
