Well Here we go!!
Ill start by saying ive never modded a pc case before so if you think im doing somthing wrong or you think you cud help in some way please lemmie know
Right onto buisness
I just Built my Lil Bro (16) a New 64bit system consiting of :
ASRock 939Dual-SATA2
AMD 3500+
1Gb Corsair TwinX 3200 (2x 512mb)
Nvidia 6600GT AGP
and at the time of built i could only get a Cheap plastic case in red its sooo Chav it scares me
So when i bought my new Thermaltake Tsunami Dream i got an idea. Kill 2 birds with one stone, Mod my Raidmax Scorpio 868 and give it to him for xmas...
The mod has started and is a bit thru but ill start with pics from now on.
For people that have no idea what a Raidmax scorpio is heres a picture (mines is Black)
First thing i wanted to do was to get rid of that stupid looking side window... so i took a 5" grinder and a Ultra thin Cutting disk and cut it out and too off rags with a needle file...
Cuts Dont look to bad tbh who needs a dremel!!
Bare in mind the case is getting painted so paint chips are no worry.
I bought some plexi 6mm thick and traced thru from the side panel and drilled 5.5mm holes for Stainless steel Button head bolts to hole the window in place.
FRONT PANEL
The plan for the front of the case is To Flush off the Grilled area and then create a front mounted Blowhole and have a custom made aluminium Blowhole duct made. the Door area has still to be decided yet
I took the door off and ground down the plastic in the grille area, down far enough to allow to Put in Mesh for the Bodyfiller (Bondo for the yanks in the house
) to grip too.
i then cut a peice of Aluminium mesh and araldited it onto the front panel.
Closer look at the mesh
What you think so far guys???
I have chosen the colours for the outside and inside of the case but ill keep stum atm.
C&C please. More updates soon
Dan
Right onto buisness
AMD 3500+
Nvidia 6600GT AGP
FRONT PANEL
Dan
