only1brian
- Sep 6, 2006
Ive finally got out and bought some materials and acquired an old case to make my first attempt to modding and painting a case.
I want to make my first attempt look nice and simple.. my plans are:
- Red gloss paint for exterior
- White interior
- Side window
- 92mm front fan, 2 80mm back (if they fit)
- new on/off and reset switches
- feet
Case Untouched:
Sanded 320 grit - primer - wet sand 600 - primer - wet sand 1000
White!
3 coats of red:
Hopefully by tuesday the coats will be fully dried and ready to wetsand 1500grit.
Then ill do a finally few coats, followed by clear coat at the end of the week.
In between that time, i will be ordering the fans and other parts to complete the project. As well as more planning - prep and planning.
- White interior
- Side window
- feet
Case Untouched:
White!
3 coats of red:
