boardsportsrule
- Nov 27, 2003
Ok, i have decided to start posting my progress, so im kinda in the middle of this, so i have some catching up to do. I decided to water cool my pc, but with limited space in my tower i wanted to go with a external unit. At first i was going to make it totally disattached from PC, but after a while i had an idea of making it attach to the bottom of my case. Transportation would be easier, electrical stuff would be easier, the pump would work less, it just seemed logical. The basic theme here is fire and water, heat and cold etc. my motherboard pumpes off a lot of red, so i had to throw that in, and i like blue so it works
any ways, enough talking here comes the photo's
computer specs
abit An8 ultra
a64 3200+ venice(hoping to go X2 some time soonish)
mushkin redline 4000, 2X512
6600GT(zalman 700-cu cooler)
200gb seagate hdd
audigy 2
here's the victim. Notice the piece of plexi on back(covered in brown paper)...thats where the PSU went...right above the CPU
this was my original idea for my res. After some more thought i dont like it...to big, to normal...im not sure what im going to do now... my main idea is having a2 diameter acrylic tube that goes on the side of the box. Or a bay res..not sure...
another thing of the past are these quick connect things. I was going to put them on the back of my case for easier disconnect but with new design i dont need em.
so this is my shroud... i have 2 of them..this ones painted, but not clear coated...i had them just clear for a while, but i think with the blue, and then throw in some white LEDs inside....should look nice.
none of this would be possible with out 2 excelent tools..first a 90* clamp... helps so much! Second the best glue in the world for acrylics..
computer specs
abit An8 ultra
200gb seagate hdd
audigy 2
