After many years working with big cases, i desied to buy an Shuttle. Every time to lanparty's with an big and heavy case is not something i wanne do every week. So i boucht an Shuttle (the SG75G2).
My computer has the folowing configuration:
- Intel Pentium 4E 2.8GHZ FSB800 1MB CACHE
- 2x 512MB DDR PC3200 (kingston)
- Shuttle SB75G2
- Seagate Barracuda 160GB 8.5MS 7200RPM 8MB
- Asus FX5700 AGP8X 256Mb Ret nVIDIA, Tv-out DVI
- Acer L1721ms - 17" - DVI - 16ms - 1280 x 1024
- Pioneer DVD 16x40 IDE Oem Slot-In / 120S
- Pinnacle PCTV Pro (was al in mijn bezit)
- Logitech MX500 (was ook al in mijn bezit)
- SafeWay Multimedia Toetsenbord
Before i started with modding.
Cutting the fanguard for better airflow.
An home-made RGB ledfan.
Fan mounted on case.
VFD (4x20).
Dremel'd the front (steel) of my case, as cable holes for the VFD.
VFD Mounted (inside).
VFD Mounted at case (outside).
After cutting the front audio+usb+firewire connectors.
The MIC connector (into the WiFi hole).
Front connector
Internal Bluetooth function.
PCB with cables for the VFD.
VFD working, some info shown.
Some Motherboard Monitor information (via LCDHype).
Cutted the front so the VFD fits.
The first wooden plate, i used Polyester as glue.
The 2nd plate, with hole for the DVD-rom and VFD.
Filler / Bondo
Front is almost done, after shaving.
The original sideplates from my shuttle, and the new one.
Preview
Showerhose.
The showerhose parts.
Showerhose at right site (incl. new steel side).
After cutting the showerhose, this is the result.
Now i have 2 weeks to mod my case, let's see how far i can get
- Shuttle SB75G2
VFD (4x20).
Front connector
Filler / Bondo
Preview
Showerhose.
