Project: Great Pumpkin
Looking at a lot of cases noticed one major issues with all of them. They are build with a lot of extra space in them. Now because they are build to accommodate everyone I can see why but I knew what parts were going into my PC so the extra space was just that, extra. So I set out to build my case with only the space "needed". Final dimensions are 15w x 15d x 9h. This will house a 5 120mm fans, full size mobo, fully size PSU, dual 220 rads, 8800gts (SLI once I find another 8800gts [640meg] cheap enough) and water cooling for cpu, gpu, nb and sb.
Project "Great Pumpkin" is a Halloween themed case (15w x 15d x 9h). Originally I wanted to build the case out of just sheet aluminum but after laying it out I knew it would be too hard to get at everything so I went with L shaped aluminum strips for an inner skeleton with a sheet aluminum skin. The case is nearly 100% custom. The only thing I am using is an old HDD holder and the back side of a tray.
Mobo Evga 750i FTW
CPU Intel Core 2 Duo E8500 Wolfdale
Video Evga 8800GTS
Audio Creative X-Fi Xtremegamer
PSU KINGWIN Mach 1 ABT-800MA1S 800W ATX
Ram CORSAIR DOMINATOR 4GB
Fans 5 Scythe S-FLEX 120mm orange/black
Pump Swiftech MCP655™ 12 VDC Pump
Rads 2X - Swiftech MCR220 "Quiet Power" Dual
Water Blocks
CPU Swiftech Apogee GT
GPU DD-8800-GTS
SB EK-SB VGA 790i Southbridge Water Block - Acetal
NB EK-NB 780i Northbridge Water Block - Acetal
Dry fit. I was a little worried about the PSU being so close to the CPU block but I believe it should be fine. When I mapped everything out I had a lot more room but as you build plans change quickly.
90% of the fabrication is complete. I just need to make the fan grills and paint it. Sadly I am running out of time before QuakeCon but I'm pretty sure I'll get it finished in time.
Plexiglass front and gloss painted frame.
She's got paint.
Starting to put it together. Sadly I don't think I'll get the grills finished by QuakeCon. But I'm not giving up just yet.
