Hi all modders!
Here is my first try to write a project log on english, Im from sweden and my english is not the best but I can give it a try
The case I use is Coolermaster Stacker and it seams to be a very nice case.
I going to have 2 watersystems
and here is the components: 2 Hydor L30 pumps, 1 black ice xtreme singel, 1 black ice xtreme dual, antartica cpu block whit homemade top, Dangerden Nv-78 gpu and then some homemade block for nb, ram and hdd.
enaught talking and over to the pics :thumb:
Some pics on the Stacker
Some planing for the wc setup
I cut out some acrylic to cover the radiator and pumps in the bottom of my case and im going to paint it black later
Sketch
Cuting
Finished
Here it's in place
Im trying to make some fangrills in acylic to
Dremel work
just some finishing left
Finished
Cut out the holes for the fans in the coverplate
Now I have painted the plate and I also made a second one thats goning to be under the bix singel rad and I have order one more turbine fan for the rad.
thats all for now and I hope you like it and that my english is not so bad
Sketch
Cuting
Finished
Here it's in place
Dremel work
Finished
