I"'ve been looking at a way to inexpensively get better audio for my PC. I got tired of waiting for my next bit of income, so I decided to try a project I had been mulling over in my head hoping it would turn out better then I anticipated.
Project name: CheapBass
Project goal: richen my audio experience as much as possible in the low end with a budget of $0 and the parts I had on hand
My girlfriend had moved in recently, her car is no longer in working order, so no reason to leave the car audio in it. only thing worth saving is the kicker solo-baric dual voice coil 10" square sub, sealed sub box designed specifically for this sub, and a sony mono amp with a rating of about 300 watts RMS into 4 ohms (which is what the solo-baric is when the two 2-ohm coils are in series). I'm thinking, Kicker, Ive heard them, they sound horribly loose, nasty, muddy, the amp is one channel not two, I don't even want to bother. And then I read the specs on the sub... the cone is made of a much more stout material then I thought, it's got a very well built surround despite my first thoguhts, it's very well built... Maybe it won't sound as bad as the old kickers I knew...but jeez... OK Ill check the amp... can't find stats on whether it's mosfet drivers or even discreet but that high of a wattage it's gotta be discreet at least.... and it's got a low-pass... line level ins, and voltage level adjusts. Maybe just maybe I can make it sound half decent... After all the box is sealed, very thick, and made of very dense material, making for a good sub box... so off I go, project CheapBass has begun despite my misgivings.
First step was creating a passthrough for my speakers which also linked the sub amp via dual RCA jacks...
And then, I had to reinstall my AT 230 watt PSU I had previously rigged to run the SCSI array that had failed... and run power from that to the amp...
And testing it to see if it can handle the load...
Yowch! look at the voltage! better tie off the other molex so I don't try using this to power other stuff...
and more testing...
yet more testing...
Yeez, more testing... seems to be going good though! I may pull this off!
finished product... (just got the mouse and KB today wheeeeeeeeeeee!
check out the rest of my comp stuff / images, just browse these dirs
http://jaqiejean.mine.nu/pics/demia2/
http://jaqiejean.mine.nu/pics/server/
and more testing...
yet more testing...
