Project: Beast 2.8
Stevennoland
Hello avid computer users, gamers’, and system modders and builders. I’m back with another work log.
Don’t fret, Beast III isn’t dead. I’ll actually be using some of it for this build. This build will be an update to Beast 2.75; the system I’m currently using.
Since Intel released its current speed champ, the i7 series, I knew it was time to upgrade. I had done some research and concluded the 920 proc was the way to go. An X58 mobo was also in order. And to get the best memory performance, 3 x 2GB of 1600 mem (minimum) was also on the menu.
I had a spare Lian-Li / Rocketfish case lying around, so I decided to use it as the backbone. I wanted to water cool as well. I will be using many of the parts from Beast 2.75 for most of the water cooling.
This case is certainly not as well built as some of my other Lian-Li’s, but it does have some features I like. The space at the top above the MOBO section is perfect for a triple rad set-up that is actually located inside the case (unlike Beast 2.75). I can also remove all the HDD cages since I’m planning on using an SSD for the OS and progs. I can also ditch the 3.5” cage since floppies are so out. First, some shots of the case.
First step was to add some handles (these are the same ones on the doors of the CNC lathes I use at work). These suckers are beefy, and at $20.00 each, they had better be.
Here is a shot of the holes for the handles
Here are the filters I made for Beast III. Since this case has the space at the bottom, I chose to incorporate them into this build. I also wanted to cut down on the dust intake as much as possible.
Here are the cut-outs for the air flow. I used my Roto-Zip to rough these out.
Wicked burrs!
I then filed the edges smooth. Back intake.
Front intake
Holes for the rails to hold the filters
Close fit
Here is the middle rail. There are two sets of holes because some idiot dimensioned in ‘Paper Space’ instead of ‘Model Space’. If you don’t know the difference, ask someone who uses Auto CAD. Shame on me.
Here are the end rails
Here is the mounting hole (the thread is in the elbow). If you want to see how these were made, check my Beast III worklog
Rail with hole to show line-up
Attached
Here is the back end rail installed
Middle rail
Front end rail
The filters slide into position. I had intended to use four screws to hold each filter in place, but getting to all four screws once this thing is complete will be a PITA. I may only use two.
Since I want the filters to actually prevent dust from getting into the case, I had to block off all other entry points. Let’s start at the bottom. These are the holes under the PSU.
I squared up a piece of a remnant cut-out (actually the cutout for the top rad) to block these holes. The two holes in the center are for the PSU support.
Screws, washers and nuts
Installed
This is a shot of the slits below the PSU. I don’t have a remedy for this yet.
Next up are the holes for the GPU fan exhaust
Covered
Next up are the top vents
Plate
Installed
Here is the plate to cover the 3.5” drive bays.
Covered
Getting the 5.25” unused bays covered will be the hardest. I will probably use some clear silicone gel to cover any remaining air entry points. A complete seal is impossible, but I’ll certainly give it a shot.
The stock rubber feet were not going to give me the proper height for the intake filters.
So I made these. They will also provide a wider stance to reduce side tippage
Screw and washer
Installed
In this shot you can see the difference in height. More than enough for adequate air flow.
Here are some shots of the parts that will be utilized for this build. Plextor PS-850XA DVDRW
Shiny front.
SATA interface
Next up is the CPU. ‘C’ stepping I believe
I was originally going to do a GTX 280 SLI set-up, but the water blocks (front and back) for two 280’s was going to run me almost $500.00. I am currently using an EVGA GTX 280 in my current system, and I purchased this BFG GTX 280 for the SLI
I know a pair of GTX 280’s in SLI is pretty decent and more than enough for a 24” monitor @ 1920 x 1200, but I couldn’t bring myself to drop the $$$ on the EK front and back blocks. So I decided to opt out and get a GTX 295. I know, I know, I can hear the groans now, but it is far easier to cool one card than two (tubing and set-up wise). To off-set the price, I’m planning on selling the 280’s.
Here is the GTX 295 I picked up @ Fry’s (check that price!)
Candid shots (the covering on this card has the coolest rubber feel)
And to cool this beast I purchased the HeatKiller
Install goodies
I’m breaking in the 295 in my current system. I’ll have a post of the marriage of the 295 and the Heatkiller later.
Here is the MOBO. Pics speak for themselves
This shot gives you a good idea how much wider this board is (most boards end at the hole near the memory slot)
For initial testing I installed the CPU and memory
Here are the water cooling blocks for the mobo.
First, the naked nb
And sb
Next, the EK north and south bridge block with the acetal top
Looks like a quality control issue
Look at those burrs!
Inside
I was able to get the paper off, but what appears to be adhesive won’t come off. It seems like it will seal though.
Next up is the block for the CPU. This is the same block I used for Beast 2.5, but the aluminum plate had to be remade to fit the different sizing for the mobo holes.
New top plate
Next up are the mosfet blocks.
Naked mosfets
In order to get the stock heatpipes and blocks off the mobo, you are required to remove the QPI power riser card
The ‘Republic of Gamers’ lighted logo
Backside
I wanted to reuse this logo, but I had no place to put it. There is a heatsink attached to the top of the QPI card, and this lighted logo is glued to it. But when you remove the stock heatpipes and blocks, there is nothing to attach the QPI card heatsink to. So I came up with a brilliant plan to make a water cooling block for it.
See next post.
Continued from first post.
I first started by drawing the QPI card in 3D using Auto CAD, here are some JPEG shots
I thought it would be cool to have the block cool both sides of the card, so I came up with this idea
This image shows just the top copper cooler
Bottom view
Here is the bottom cooler block
Bottom view
Here is the cap for the bottom block
Here is the top cap
Some assembly shots
Side view
End view
Bottom view
With QPI power card added
Here is the actual Acetal material
Copper
Acetal squared up, bottom cap
I’m planning on making four of these (if all goes well, I plan on selling the other three)
Top acetal caps
The lot
Bottom copper
The lot
Top copper
The lot
The sandwitch
This is as far as I have gotton on the water block for the QPI riser card.
In designing this QPI water block, I ran into some interference with the EK north and south bridge block.
After many revisions and changes, I realized that some modifications to the EK block were in order.
The two holes nearest the QPI assembly were the interference area (two holes at bottom below nb)
What follows is the modification to the EK nb sb blk. I needed to extend the top acetal block but below the pin block located on the mobo (where the QPI board plugs in) Here is the process. First material, 316 stainless steel (we didn’t have any plate stock, so I cut it out of a 2” round bar)
Sawed end
Next came the square up
Holes
Clearance for the bottom copper (angles also added)
I originally had cut a slot into the top acetal block, but it wasn’t low enough. The five mounting screws
Here is the extension attached (screws are a bit too long)
Here is the extension after grinding
Here is the top block with the shelf removed
Here is the top with the extension attached
Proper length screws
More views
Top view with stainless screws to affix the top to the copper bottom
Here is a shot of the new nb sb block set in place. Can you see what is blocked?
This shot might give it away, the hole nearest the top memory slot
I still haven’t figured this problem out yet.
Here is another little clearance problem
The lock release for the PCIe slot is blocked. Another view
I could modify the acetal top block or shave a portion of the lock release off. I haven’t decided. I can tell you I’m a little disappointed with the design. EK should be ashamed.
Here is the modification to the top of the case for the fitting of the x3 120mm rad and grill. This is a shot of an aluminum block attached to a scrap piece of plexiglass. I affixed the top of the case to this to machine the opening for the rad (actually the fans). The block is so I can grab this monster in the vise we have on the mill.
Does the plexiglass looks familiar? It’s the same piece I used for machining the B3 in the door for Beast III
Cut-out!
The x3 120mm rad and fans
Top in place
Rad in place
Close-ups
Screwed and handles added
Close fit eh?
That’s all for now. I’ll have more to post a little later. I’m working on refitting the power cables for the GPU.
Stay tuned!
This looks really good. I'll be keeping an eye on this badboy. ;)
By the way, that is a killer deal you got on that GTX 295! I'm jealous, lol.
This is incredible. What kind of equipment are you using to cut all of this?
amazing job so far man! beautiful in every way. you have some unbelievable skills.
sorry to hear that your EK block didnt work out. :( i would go with trimming a bit off the block since youve already modded it. that way you can keep the warranty on your mobo. (assuming it hasnt already been voided.) otherwise i suppose the lever would be easier to fix.
damn good work here. having access to a CNC mill is so nice, but man i hate standing there for hours just squaring up the stock, let alone actually making something! :D
Back with more! Thanks for kudos people.
I know the DDC pumps can be mounted in any direction, but I wanted to keep them upright (if that is the correct term) with the inlet at the top. I was limited on space, so I decided to make some brackets.
First, the material. This is 6061-T6 aluminum. I have been informed it is called ‘channel’. If anyone has a more correct term, please let me know.
3 inches high
This was the smallest remnant Industrial Metal Supply had. The sales guy sold it to me for less than $18.00 . A good deal if you ask me.
Next, I cut it into rough shape on the cut-off saw. I ended up with ten blanks. If anyone wants one of these made, PM me and we can work out a deal
Machined to size
I didn’t need the angled surface, so I left it alone.
Mounting holes
Nice burrs eh?
Next up, the window for the fitting and the mounting holes for the plexi top.
Pump attached
Close-ups
Here are the templates for the L brackets in the case
Mounted
I made these brackets to help even out the load.
This is the solution to the covered mobo mount hole the EK nb sb block created. I figured I would incorporate the mount into the mobo and secure it with a nut. First, the stand-off
With washer and screw
Installed
Shot of normal stand-off mounting hole
With stand-off
Back side
Opened up
Mobo installed
Secured with 4-40 nut. This was the easiest remedy. Another alternative was to drill holes in the mobo tray where the mounting screws for the nb sb block are, and secure the block after I installed the mobo.
I got a little more done on the QPI power riser card water block. The top cap
With fittings
Top copper block
Bottom copper block
I got a little inpatient and broke a tap off. I’m hoping it won’t cost too much to have it burned out.
My PC Power and Cooling 1KW PSU does not come with PCIe 8 pin power connectors, so here is the remedy for that. First, a regular 6 pin connector
Here is the 8 pin adapter that came with my GTX 295 next to the 6 pin
The only thing that is different is the addition of two ground wires. This is completely stupid and is a conspiracy between GPU and PSU manufacturers to sell more PSU’s
Female PCI pins
I made this extractor a long time ago. It is a piece of banding strap ground to about .04” wide (.03” thick)
I just push it in on each side of the pin
TADA!
In this shot you can see how the wings on the pin are bent inwards allowing for housing removal
6 pins removed
Stripped
Here are the new pins with the addition of two ground wires added to the existing ground wires (I know it looks like shit, but I swear these pins are not designed for more than one 18 gage wire per)
Installed with new heat shrink and zip tie
That’s all for now.
Wow, there are so many detailed images on this build, it's bordering on pornographic.
i did the exact same thing with my power supply. it is very difficult to get 2 wires on one pin. the others are cake.
Damn dude, your Rocketfish is simply amazing. If I had the money...
... I couldn't do that. :(
