JDM_WAAAAT
- Oct 5, 2008
DAY 1
I'm definitely not the first person to do this mod, but I was commissioned to do it. (and I wanted to make it proper and not half-ass like others I have seen)
Some of you might know me as the young kid that won Guru3d's October rig of the month.
I;m taking a .50 cal ammo box and putting an ITX style motherboard and mini power supply inside it. I'm also going to attempt to squeeze a naked wireless router inside the box. (for lan parties) I want this to be a power efficient computer... while looking bad ass.
I have a few unannounced surprises, so be prepared...
Hardware
Intel Atom 330 Dual core (hyper threaded - 4 threads)
1 x 2gb DDR2 800 Dominator
Rosewill 4 port USB hub
160gb 2.5" HDD (SATA)
250w SFX12V power supply
4 port USB PCI card (1 internal port)
possible - Slim DVD drive
Most of this stuff will be in tomorrow, so I will post pics then. (and by tomorrow, i guess i mean today.
My plans are to put a window on the side that does not have any text painted on it. The window will be as large as possible. 3 x 80mm fans will be used as exhaust out the bottom of the case. (not sure about intake or ventilation yet)
The USB hub will be plugged into the internal port of the PCI card, and be wired toward the roof of the box. There, a USB wireless adapter, Bluetooth adapter, and 16gb storage drive will be plugged in. (for linux boot?) The other port will be a surprise... =]
And the best part, in my opinion, is that the entirety of the wires inside this mod will be Murder Mod Style.
Here are some pics to hold you guys over until later today...
Oh yeah, product budget is $300. =]
EDIT:
Just ordered from performance-pcs.com
120' 1/8th inch tec black
appropriate heatshrink
microcool heatsinks
Hardware
EDIT:
microcool heatsinks
