Programs for OC'ing CPU/Vid card?
joecuddles
I have a Gigabyte GA-MA770-UD3 Rev. 1, Phenom II X3 720 and a Sapphire 4890 OC. I'm wondering what utilities I should be using to OC and stress test the CPU/GPU. Is ATI Tool still around? Gigabyte boards come with EasyTune 6 which looks like a nice all in one solution. What should I be using?
you should be using the bios to overclock the cpu.. and using OCCT to stress test the cpu and gpu.. and use the cat control panel to overclock the 4890..
the x3 720 is simple to overclock.. all you have to do is change the multiplier and voltage.. you dont have to touch anything else..
