Don't know where i should post this problem since RadeonPro deosn't have a forum or community.
Just installed RadeonPro and noticed two things.
* FPS counter and taking screenshot doesn't work at all.
I did some reading i Troubleshooting
Well, i've looked up everything and no problems there. Still no FPS counter etc.
*All games that i've created a profile for launches with Directx9. No clue why since there are no settings that handle DirectX in RadeonPro.
Q- The OSD functions (FPS counter, etc.) are not showing up after a reinstallation.
A- Newer versions of RadeonPro only activate OSD functions on games that have a profile defined for it on your profiles list. If you want to have the OSD functions working for every game, open RadeonPro settings and on Advanced section, uncheck the option Disable API monitoring for programs not listed in my profiles list.
Q- The OSD functions are not working on my games.
A- If the above answer didn't help, you may need to update your DirectX runtime. RadeonPro requires February 2010 or newer DX runtime to be installed, if the version installed is already up to date but the OSD still doesn't show up, try to update the DX runtime anyway as some component can be missing or got corrupted. To download the latest DirectX runtime, visit:
http://www.microsoft.com/downloads/...38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
