shadowwyvern
- Sep 22, 2005
My friend is having this problem, but he does not have a real email address so he cannot register to post at the moment, and time is something of a factor, since he uses this daily. This has us both stuck, thanks for your help.
Alright so my school has an exchange server, the settings are available here: http://clarkson.edu/oit/applications/files/setup_outlook.pdf And I have it set up on my laptop using Outlook 2007. It works fine save for the fact it refuses to remember my password. I tried setting it up on my desktop so my PDA can sync to it, and it doesn't work. It refuses to connect. Everything I try results in a hang until Outlook times out, then the following error message:
The connection to the Microsoft Exchange Server is unavailable. Outlook must be online or connected to complete this action.
Windows XP SP2, tried it with Outlook 2007 and then 2003 exact same result. And my laptop, on the same internet connection a foot away is working fine. No firewall, I trust my router for that, and aVast personal edition, but I tried disabling that, it was no help. I have also tried the customary reboots and such.
I've run Wireshark on both machines and there is a plethora of traffic on the working one and a decent amount of back and forth traffic on the non-working one. As far as I can tell its connecting fine which rules out a configuration problem. I have also tried it from a clean install of XP on a VM with a fresh install of Office 2007 with the same results. As far as I can tell the connection is going through, I do get prompted for my password and if I enter the correct one I receive the hang/timeout/error. If I input the wrong one it immediately re-requests it. ♥I have also tried changing my password, that went fine but even with the new password, same symptoms, works perfectly fine on laptop, and timeouts on desktop. It would appear the problem is at the remote end because of these symptoms except my laptop continues to work perfectly. Thanks
