munkeypants07
- Dec 6, 2004
i'm really not sure what to do about this. C&C Generals Zero Hour crashes after about 10 minutes, and i have to reset. but without the expansion, it doesnt. I just got LOTR: Battle For Middle Earth, which uses the same engine, and after about 30min it did the same thing. At first i thought it was just the software, cuz apparently a lot of people have the problem with C&C GZH. but now i'm thinking it must be something with my computer.
MBM5 doesn't support my motherboard, but i used the utility i got with it, and it says my temps are fine, idling at about 45* celsius. all my driver's are up to date, but there is an update for my BIOS that "fixes SP2 problems" and i have SP2.
also, my power supply isnt the greatest, and i have a lot of fans, but everything seems to be normal...
so, what should i do?? any ideas as to what's causing the crash?
