Hey all. Yesterday I finally got my order from newegg, a black Chieftec case and a new Abit IS7-E motherboard. I stripped my main rig (in my signature) down, mounted the new motherboard in the new case, and moved everything over. I was wearing an electrostatic wrist band the whole time, and the table was covered with anti-static bags...
So I hook it up, turn it on, and it startes to boot into Windows. BSOD. No big deal, Windows is usually screwed up after you change motherboards anyway. I do a recovery install, now it's even worse... So I delete the current partitions, create a new NTFS partition, and install from scratch... Now, it will get to the Windows logo with the little progress bar thing under it, and the screen just goes black... There's still power, although the hard drives have kicked off... I try clearing CMOS, no go... So I reinstall again... Same thing... Tried a different CD and CD drive, same thing...
I've checked everything I can think of... Any help at all would be appreciated. I'm using my laptop at the moment...
Here are full system specs:
P4 2.66BghZ CPU
768mb RAM (1x 256, 1x 512) pc2700
Abit IS7-E Mobo
GeForce4 ti4200
Older PCI graphic card to power a smaller third monitor
Seagate 120gb 7200RPM IDE hard drive
WD 13gb IDE backup hard drive
Sony CD burner
NEC DVD burner
Floppy drive
Chieftec case
Thanks everyone
P4 2.66BghZ CPU
Abit IS7-E Mobo
GeForce4 ti4200
Sony CD burner
NEC DVD burner
Floppy drive
Chieftec case
Thanks everyone
