Problems with booting to CD-ROM
hatecc
Ok I want to boot to my windows cd and it won't seem to do it. I previously had 1 dvd drive and 1 cd writer but the DVD player failed so i disconnected it. And here is my boot device order:
1)floppy(dont have one btw)
2)CD-ROM(only gave one option btw)
3)HD 1
and it says booting to ATAPA CD-ROM but i think that's the dvd player that's no longer there.
Now my HP writer is a much older drive, we are talking probably 7+ years, but is there a way to get my bios to boot to that drive?
thanks, lemme know if you need anymore info
Hold down the delete key at the post screen and that should bring you to the BIOS.
Disable everything but the CDRW and go from there.
i actually figured out the reason, the cd im using is not booting to correctly.
it's an ISO from msdnaa of XPpro, trying to figure out why its not working now
