I have the following
fx53 w/thermalright xp-120 &120mm delta
neo 2 platinum
2x512 corsair c2pt
120gb seagate sata hdd
6800 ultra
Antec truepower 550
I can overclock to a 215fsb with no problem at all but if i go to 216 (2592mhz). or above the computer wont post. I even had to clear the cmos once. 216 isnt very high at all so there must be somethign im neglecting here....this is where you come in hopefully
cpu voltage: Stock all the way to 1.65 still nothing
vdimm v: 2.85
timings: 2.5-3-3-10
spread spectrum off
agp/pci locked (port 3)
etc etc.
With what i have what would make it suddenly stop working at 216 fsb. Is there a setting i am leaving out or something i am doing wrong? I know the rami have isnt the best overclocker but im only going to a 215 fsb so that shouldnt be a problem yet....nor would 1mhz make or break the chances of getting to post. Oh and for some reason even though the mobo has the cpu ratio option and the cpu i have is unlocked anytime i try to change the ratio it forces me to clear the cmos....WTH?
neo 2 platinum
2x512 corsair c2pt
6800 ultra
Antec truepower 550
vdimm v: 2.85
timings: 2.5-3-3-10
spread spectrum off
etc etc.
