Right now I'm trying to hook up a EPIA VIA Mini-ITX motherboard up to a cheap little flatscreen monitor I have, but the monitor only accepts composite inputs (its more of a TV than a monitor), while the motherboard has S-Video out. So I bought an S-Video to composite cable and fired the bad boy up. Unfortunately, it didn't work - the monitor receives no video. But, when I hook the computer up to my regular TV with a standard S-Video cable everything works fine. From that point I can unplug the S-video cable, plug in the S-vid to composite cable, and hook up the small monitor and everything works perfectly. Unfortunately, upon rebooting, I'm back to where I started, receiving no video. I'm running Windows 98 SE. (Hopefully all that junk made sense. I'll try and clarify if needed.)
I'm assuming that my problems are due to the S-video to composite switch. What can I do?
I posted this on another forum (Something Awful's SH\SC), and the closest solution I got was:
Unfortunately I'm already using a high-quality converter, and I'm out of ideas.most s-video out cards check to see if a signal is being sent back or held on the ground wire. only adapters that have capacitors built in to store the charge allow for that signal. a 5-6 dollar adapter won't work, i had to pick up a $20 adapter at radio shack, and my rf-modulator works as well.
