Greetings all,
Ok, I've been trying to get this system to work again for a couple of years now. Ever since I pulled it out of my case and put in new insides to make a new computer this old K7T266 hasn't worked. Finally I've run out of ideas and thought I'd ask.
As I said I have an MSI K7T266 Pro. The chip is an old AMD TB 1.4 - two sticks of RAM that I was able to confirm are working. I've taken the chip out and don't see any damage there. The insides of the computer are sitting arrayed on my desk here ( I don't think the motherboard is grounding out on anything - just sitting on the wood of the desk) - the motherboard with just the cpu (HS as well) and RAM plugged in.
I have an extra power supply that seems to work - when I jump the blue and the green wire on the 20 pin plug and flip the switch on the back of the PS, the PS fires up (Fan on back turns on and it powers a simple 80MM fan on one of the 4 pin plugs used for testing).
However - when I plug it into the PS slot on the motherboard and jump the two power pins on the motherboard I get no response at all. No beeping from the motherboard - which isn't surprising since the power supply doesn't fire. Am I right in thinking that it's probably the motherboard that's dead? Perhaps an interruption somewhere between the power connection and the power pins I'm attempting to jump? Or am I just totally missing something obvious here.
Please help - running out of ideas and I'd like this to be my secondary folding box / irc box - my current one is oh-so-aged and a pain to use.
Thanks!
Thanks!
