Problem with my Hardcano 9 - Please help!!
RandysWay
I have four internal fans mounted to the case and connected to the four fan controls "correctly" (I think.) Each fan goes to one fan control. All of the fans work but when I turn the knobs, nothing happens. I rewired it three times and it still does nothing when I turn the knobs.
Knobs dont work with the Q-Fan Control either on or off.
Any suggestions?
Thanks in advance,
Randy
I may as well post this incase somebody stumbles upon this one day with the same problem.
The Problem:
Fans dont change speed when you turn the knobs.
The Answer:
I started looking around when I was hiding my wires, and noticed.. drumroll.. The PCB Power Connector plug on the back side of the Hardcano 9 was unplugged. Powered up and it WORKS! :)
Randy
