Hi
First of all, sorry for this bad english you're about to read![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
iam haveing this problem, since i kompiled a new kernel, i cant get my root drive running with dma, and i cant figure out whats wrong with my kernel config.
Here is an output from hdparm:
/dev/hda:
multcount = 16 (on)
IO_support = 0 (default 16-bit)
unmaskirq = 0 (off)
using_dma = 0 (off)
keepsettings = 0 (off)
readonly = 0 (off)
readahead = 8 (on)
geometry = 14593/255/63, sectors = 234441648, start = 0
/dev/hdc:
multcount = 16 (on)
unmaskirq = 0 (off)
using_dma = 0 (off)
readonly = 0 (off)
readahead = 8 (on)
geometry = 2481/255/63, sectors = 39862368, start = 0
/dev/hdd:
multcount = 16 (on)
unmaskirq = 0 (off)
using_dma = 0 (off)
readonly = 0 (off)
readahead = 8 (on)
geometry = 3722/255/63, sectors = 59797584, start = 0
/dev/hde:
multcount = 16 (on)
unmaskirq = 0 (off)
using_dma = 1 (on)
readonly = 0 (off)
readahead = 8 (on)
geometry = 9345/255/63, sectors = 150136560, start = 0
/dev/hdg:
multcount = 16 (on)
unmaskirq = 0 (off)
using_dma = 1 (on)
readonly = 0 (off)
readahead = 8 (on)
/dev/hdh:
multcount = 16 (on)
unmaskirq = 0 (off)
using_dma = 1 (on)
readonly = 0 (off)
readahead = 8 (on)
geometry = 9729/255/63, sectors = 156301488, start = 0
As you can see i have 6 harddrives, but the first 3 of them dosent run with dma on, and thats taking all my servers cpu power then iam working on them. Like i sayed i'd never had this problem before and, i think it must be something with my kernel.
When i tries to force the drives to run with dma i just get this message:
root@prohest:~# hdparm -d 1 /dev/hdc
/dev/hdc:
setting using_dma to 1 (on)
HDIO_SET_DMA failed: Operation not permitted
using_dma = 0 (off)
root@prohest:~#
uhm, well i really dont get it, when iam root, shouldent i have the rights to everything? anyways, it says the same error on every 3 first harddrives. (hda, hdc and hdd)
Iam running Slackware 9.0. with kernel 2.4.23
just some more info that might help somebody help me![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
lspci gives this:
00:00.0 Host bridge: VIA Technologies, Inc. VT82C693A/694x [Apollo PRO133x] (rev c4)
00:01.0 PCI bridge: VIA Technologies, Inc. VT82C598/694x [Apollo MVP3/Pro133x AGP]
00:07.0 ISA bridge: VIA Technologies, Inc. VT82C686 [Apollo Super South] (rev 40)
00:07.1 IDE interface: VIA Technologies, Inc. VT82C586/B/686A/B PIPC Bus Master IDE (rev 06)
00:07.4 Bridge: VIA Technologies, Inc. VT82C686 [Apollo Super ACPI] (rev 40)
00:09.0 Ethernet controller: Intel Corp. 82557/8/9 [Ethernet Pro 100] (rev 05)
00:0d.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8029(AS)
00:0e.0 Unknown mass storage controller: Triones Technologies, Inc. HPT366/368/370/370A/372 (rev 04)
01:00.0 VGA compatible controller: Silicon Integrated Systems [SiS] 86C326 5598/6326 (rev 0b)
as i see it there should't be any thing wrong...
Regards
/dev/hda:
multcount = 16 (on)
unmaskirq = 0 (off)
using_dma = 0 (off)
readonly = 0 (off)
readahead = 8 (on)
/dev/hdc:
multcount = 16 (on)
unmaskirq = 0 (off)
using_dma = 0 (off)
readonly = 0 (off)
readahead = 8 (on)
/dev/hdd:
multcount = 16 (on)
unmaskirq = 0 (off)
using_dma = 0 (off)
readonly = 0 (off)
readahead = 8 (on)
/dev/hde:
multcount = 16 (on)
unmaskirq = 0 (off)
using_dma = 1 (on)
readonly = 0 (off)
readahead = 8 (on)
/dev/hdg:
multcount = 16 (on)
unmaskirq = 0 (off)
using_dma = 1 (on)
readonly = 0 (off)
readahead = 8 (on)
/dev/hdh:
multcount = 16 (on)
unmaskirq = 0 (off)
using_dma = 1 (on)
readonly = 0 (off)
readahead = 8 (on)
/dev/hdc:
using_dma = 0 (off)
root@prohest:~#
lspci gives this:
Regards
