I am having a strange problem with my Dell 2407WFP monitor, which I just got a few days ago. Its a little hard to describe. Occasionally the monitor displays dark, horizontal lines, that kind of move up or down. It seems like they are rolling. I tried to take a picture and video of it but the problem doesnt seem easily visible there.
I am currently running the monitor through VGA on a 6100 IGP
. I have tried changing the VGA cable, changing the power cable. Since the problem reminds me of EM interference that CRTs used to display when near something like speakers etc. I even tried unplugging and moving away my speakers, moving my CPU off the desk and away, even though I know LCDs arent susceptible to this kind of problem.
I dont think that the problem is with the monitor per se, as this is already a replacement. When my order was delivered to me, it had a dark, un-removable, 1cm diameter smudge near the center of the screen, along with this problem. It was the A04 revision. So I had it RMAed. This monitor is a replacement, and it's new (not refurbished) though its A03 (I dont really mind, since I dont intend to use component anyway). But this monitor also displays this problem. I am running this monitor off an 800VA UPS. I tried plugging it directly into the mains, as well as running it only on the UPS (by turning off the mains) but the problem is still there.
Havent had the opportunity to run it on DVI yet.
If anyone experience with this or has the solution, please let me know.
Thanks
Thanks
