problem with changing drive letters
bealzz
Hi everyone,
I currently have 3 partitions on my computer, 1 for my os C:\, 1 for primary storage D:\, and 1 for secondary storage E:\.
Ive usually always had them in order but after my recent OS reinstall secondary storage is now D: and primary moved to E:
Well, that wouldnt be a big deal if i could change the drive letters, which i can on the secondary storage drive, but for some reason my primary drive is labeled as the system drive and has all the ntldr and boot.ini stuff...
I dont know how this happened, but i was wondering if anyone knew how to move my system drive onto the boot drive so i can change the drive letters.
I should point out that there is nothing installed on the primary storage drive, i use it for exactly what it sounds like.
heres a pick from disk management in case it helps clarify things a bit
Is it me or is that folder for batman begins the movie? I dont believe that it is even out yet :eek: .....other than that, Im sorry I couldn't help you...I just wanted to point that out!!! :D
most def that folder is in the wrong place... should be in bob fart's share
its not the movie unfortunatley, just some trailer videos for the videogame
i figured out the drive change also. had to change the letter in the registry. it seems that it doesnt matter what drive letter you give your system drive, only your boot drive
what ta hell, how do you know about bob fart spank monkey!?
