Problem overclocking a8n32
madmaxz
not really a major problem just annoying as hell.. i have the reset the cmos (take battery out) everytime i want to change the FID/VID CPU multiplier. ill set it, restart, the overclock worked then i restart get back into the bios and the FID/VID multiplier is blacked out and i cant change it again! any ideas?
so i tried updating the bios.. no go wont read the a8n32703.rom, tried ez-flash, it doesnt do anything besided beep beep beep over and over again while reading the ROM file. tried afudos and got ERROR cant read a8n32703.rom tried a couple different disks and redownloaded the file a couple times. ASUS tech support is worthless! i asked them about the FID/VID issue and they said they couildnt help me because they dont support overclocking and to call AMD bucause my AMP VID is locked... WTF is this
aright i figured out if you disable the cool n' quiet option you then can change the multiplier and i used the asus updater program to update the bios.. worked great currently running 3.02ghz 275x11 at 36 degrees c idle with xp120 and panaflow ultra high speed
