Hi there everybody...
I'm working on making a network between 3 computers which are far from each other, one in each house... The network will be used to share Internet acess through a Router...
The first client PC is obviouslyt near the Router, so there were no problems...
For the second client PC, 40 meters far, i used a very good RED colored cable which my friend gave me...I'm not sure about this, but I think it's a Gigabit cable, with written on it 600 HZ or something like that... Everything went fine
For the 3rd Client Pc, 50 meters far, I had to use a normal CAT5 cable, but unfortunately, I couldn't have any data transfers at all.. The client detects it was connected to a network, but nothing moves from there, and it can't get any IP from the Router's DHCP...
I assume that the problem is with the cable... I must say that the cable had to be "hung in the air" for some meters, and maybe the network didn't work because of that, or because of some tension, or something like that, where the red gigabit cable could support such conditions..
As far as I know, Cat5 cables are good for netwroks up to 100 m, so the length can't be a problem...
Do you have any advices guys??? Am I missing something??? Do u have any idea what could be the problem??? Or maybe I should simply buy Gigabit cables??? (even if I'm not using Gigabit ethernet cards!!!)
Thank you in advance..
KamaL![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
KamaL
